Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 30
th
, 2024, 11:26am
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› reference buffer for SAR A/D ?
Previous topic
Next topic
reference buffer for SAR A/D ? (Read 3203 times)
Ajay
Asia
Apr 30
th
, 2012, 12:55pm
I have a SAR A/D converter and I need to make a reference buffer for it. The buffer has a big capacitor of a few micro-Farad connected to it. This acts a voltage source for the capacitive DAC array. What type of an op-amp architecture do I use for the buffer ? A 2 stage miller compensated opamp may not be suitable since the compensation cap. will be in pico-farad only. Any ideas / suggestions will be appreciated. Thanks.
IP Logged
carlgrace
Berkeley, CA
Re: reference buffer for SAR A/D ?
Reply #1 -
May 11
th
, 2012, 1:25pm
Single-stage op amps get more stable as you increase the load capacitor. Since you have such a large cap, maybe you should look into a single-stage op amp buffer.
IP Logged
pixel
Reply #2 -
May 18
th
, 2012, 3:00am
In this case type of the output stage and buffer speed are specially important.
What is the resolution clock frequency and total DAC capacitance of your ADC?
IP Logged
Reply #3 -
May 24
th
, 2012, 1:30pm
you are driving a capacitive load.
OTA with a push pull output.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
