Jul 19th, 2024, 10:29am
enabling warnings for oxide breakdown in spectre (Read 2560 times)
sriram
May 10th, 2012, 9:00am
I am performing power amplifier simulations using STmicroelectronics technology.
I am trying to do a large signal HB simulation and I want to know when the device oxide breaks down. However, even when I increase the VDD and input power to unrealistically high numbers, spectre does not show any warning messages on the oxide breakdown.
I used to get these messages before when I used the IBM technology. I am wondering if there is a switch I could turn on or something.
Can anyone help me with where to look for to enable this warning?
This might be technology specific though Sad
Sriram
Re: enabling warnings for oxide breakdown in spectre
Reply #1 - May 25th, 2012, 5:30am
Did you try looking at "spectre -help options" to see if there's one you can set to enable those warnings?
Also check your device models to see what if the oxide breakdown value (vbox?) is set -- and if there's a parameter to turn those warnings on/off.
