Aug 13th, 2024, 3:37am
Can I design a hysteresis comparator which is used in integration ADC like this? (Read 6637 times)
chaojixin
Shanghai
May 29th, 2012, 2:29am
I set the W/L of M2 larger than M6 to make the hysteresis curve different from the common comparator.
but I use this comparator in integration ADC which Vi1 connect to a DC level and Vi2 to a ramp wave. Vi1 never near the start point of ramp wave.
Can I design the comparator like this in my case? what's the problem of it?
thanks!
View Profile chaojixin chaojixin 278916917   IP Logged
Re: Can I design a hysteresis comparator which is used in integration ADC like this?
Reply #1 - May 30th, 2012, 1:12am
Integration ADC have  mostly stop being used.
Consider a sigma-delta method, or a VCO counter structure.
As a method to introduce hysteresis, the method and architecture will work, although there are other methods also.
chaojixin
Shanghai
Reply #2 - May 30th, 2012, 3:40am
but in fact it is not a real 'hysteresis'. the real 'hysteresis' is like this. so I'm afraid such a comparator will be sensitive to noise
Reply #3 - Jun 3rd, 2012, 2:55pm
the circuit shown will give the desired hysterisis effect, when the sizes of the devices are widely mismatched.
The original drawing of the response is incorrect, and the newer one is accurate, agreed.
chaojixin
Shanghai
Reply #4 - Jun 4th, 2012, 8:41pm
both drawing is correct. the curve in original drawing is made by setting W/L of M3 larger than M6 , and the newer one (ordinary case which has real hysteresis) is made by setting W/L of M3 smaller than M6.
my question is, does the comparator in original drawing has any drawback?
Reply #5 - Jun 10th, 2012, 1:15pm
chaojixin wrote on Jun 4th, 2012, 8:41pm:
It is only the inpput stage to a comparator.
You will probably need a second gain stage and an output buffer
pf66
Reply #6 - Aug 13th, 2012, 7:01am
Dear Chaojixin,
Your hysteresis plot will be sensitive to mismatch of M2/M6. Moreover, they are NMOS/PMOS and can not really be matched.
Any special reason why not use high gain two-stage (with possible offset compensation/auto zero at first stage) ?
Alex
