Aug 5th, 2024, 3:11am
Telescopic Cascode in 65nm Tech. (Read 3434 times)
Analog_Designer
Egypt
Aug 8th, 2012, 4:23am
I have designed a Telescopic Cascode in the 65nm Tech. and I want to ask about something I don't understand in the phase plot attached are both the topology written on it the operating point data and the bode plot (Gain magnitude and phase)
« Last Edit: Aug 09th, 2012, 3:36am by Analog_Designer »
Analog_Designer
Egypt
Re: Telescopic Cascode in 65nm Tech.
Reply #1 - Aug 11th, 2012, 4:05am
Please somebody answer me. Does that mean that people don't know the answer ?
Reply #2 - Aug 11th, 2012, 6:05pm
It could mean that people are simply not bothering to open your rar file. Perhaps you would be better served if you simply posted the figures.
Lex
Eindhoven, Holland
Reply #3 - Aug 13th, 2012, 12:27am
So what is it about that you don't understand? The phase jumping 360 degrees? I assume you understand something like cos(a)=cos(a+n*2pi) with n element of Z?
Considering your circuit, you might want to increase the NMOS cascode voltage. In this way your CS stage'vds<vdsat.
Analog_Designer
Egypt
Reply #4 - Aug 13th, 2012, 4:42am
I want to know why the sudden change in the phase like that? what causes it in the circuit?
Lex
Eindhoven, Holland
Reply #5 - Aug 13th, 2012, 5:29am
It is not caused in the circuit. It is caused in the way the phase is calculated for the waveform viewer. Try to unwrap it Wink
