Jul 17th, 2024, 1:29am
PAC PXF results (Read 3088 times)
ohms377
PAC PXF results
Jun 07th, 2012, 11:20am
Why do PAC vs PXF analysis results differ?
From the sc-filters sample and hold circuit,
I wanted to understand the difference in results
from a PAC and PXF analysis:
clockAlone      pss      period=TCLK maxacfreq=125/TCLK
directGain      pac      start=0_Hz stop=10/TCLK maxsideband=25
convGain (sout 0)      pxf      start=0_Hz stop=10/TCLK maxsideband=25
Note I modified the pxf to have the same start and stop frequency as in the pac analysis.
I have attached an image showing the results.
Forum Administrator
YaBB Administrator
Re: PAC PXF results
Reply #1 - Jun 7th, 2012, 8:08pm
PAC gives the transfer function from a particular range of frequencies at the input to a particular sideband of the output. So for sideband #23, the input is at 0_Hz and the output is at 23/TCLK+0_Hz.
PXF gives the transfer function from a particular sideband of the input to a particular range of frequencies at the output. So for sideband #23, the input is at 23/TCLK+0_Hz and the output is at 0Hz.
