Jul 17th, 2024, 3:24am
Simulating the effect of phase noise (Read 1815 times)
xtal
Salt lake city
May 25th, 2012, 12:41am
I want to study the effect of phase noise on my circuit performance. Is there a way I could create a source (signal generator) where I can give the phase noise number I want and then use it for simulation? Any helpful pointers would be greatly appreciated.
Manohar
ACWWong
Oxford, UK
Re: Simulating the effect of phase noise
Reply #1 - Jun 7th, 2012, 9:27am
Assuming you are using Cadence, then there is a library as part of the installation called rfLib. Inside there there is a cell called vco which is a verilogA model of what you want.
Other options are to write your own model. You can get ideas on this website:
http://www.designers-guide.org/VerilogAMS/functional-blocks/vco/vco.va
