Jul 17th, 2024, 5:27am
optimization in ADE GXL (Read 537 times)
ranran
Jun 03rd, 2012, 12:09pm
I am trying to do the optimization in ADE GXL. However, I couldn't find a way to optimize the variable which I have defined in the schematic. In the ADE GXL user guide, I could only find how to optimize parameters related to a transistor, but for my case, it is a biasing voltage (vdc), and the only device parameters related to it is called srcType. Does anyone have suggestions on how I can optimize the DC value of a voltage source in order to get an expected output which I have specified in the output setup?
Thank you.
ranran
Re: optimization in ADE GXL
Reply #1 - Jun 4th, 2012, 8:22am
problem solved... i was mislead by the ade gxl user guide, and thought it can only do optimization on parameters. I just found out it can optimize variables directly.
