Aug 3rd, 2024, 11:18am
floating body in bulk process (Read 3194 times)
Steve Mikes
Jun 14th, 2012, 2:18pm
Is there anything bad about leaving the body connection of a solitary PFET floating in a bulk process?
Re: floating body in bulk process
Reply #1 - Jun 18th, 2012, 3:10pm
Steve Mikes wrote on Jun 14th, 2012, 2:18pm:
If **none** of the connections to the transistor are attached to its probably not a problem.
However it is a very bad practice. Could make for some unpredictable behavior with substrate currents and latchup issues.
Depends on layout and if the substrate region is subject to currents.
Ground your substrate out and tie your N-wells up.
carlgrace
Berkeley, CA
Reply #2 - Jul 11th, 2012, 6:12pm
Depending on the foundry and if you're taping out for an MPW they may refuse to fab if you have a missing connection like this.  You might be able to get a waiver for it, or maybe not.
Dan Clement
Salt Lake City, Utah, USA
Reply #3 - Jul 11th, 2012, 7:43pm
If this pmos is just a switch for slow switching you will likely be ok unless you have the sub current and latch up issues described above.
I would be very leery of a floating bulk in a moderate to high speed circuit. I would also avoid using a floating well transistor in a feedback loop.
I am imagining all kinds of possibilities for unpredictable body effect, possibility of instability or noise/modulation, etc.
The nwell will tend to track the source and drain within a diode drop but you cannot easily predict the phase error or the time constant. Who knows what the floating well will do to the AC input impedance of the fet either.
All that aside I have done it before. But it's not a regular habit as its quite risky.
