Sep 1st, 2024, 12:03am
Pages: 1 2
Start-up circuits (Read 1210 times)
RobG
Bozeman, MT
Re: Start-up circuits
Reply #15 - Oct 17th, 2013, 10:29pm
If you put up the schematic maybe we could offer suggestions - hard to help otherwise.
Alberto
Analog Circuit
Designer
Mexico
Reply #16 - Oct 19th, 2013, 2:23pm
RobG wrote on Oct 17th, 2013, 10:29pm:
Hi RobG thanks for the suggestion, the schematic is the next picture
Alberto J. Gutiérrez
View Profile Alberto aljegu   IP Logged
RobG
Bozeman, MT
Reply #17 - Oct 19th, 2013, 9:40pm
I haven't seen that one before and it isn't immediately obvious that R1 won't keep it from starting up reliably unless you force the operating point quite a ways from the 0 state. Basically you have to get the diodes turned on so that the delta-Vbe is greater than the I*R1 drop or the circuit won't wind up....  The problem is that the R2s steal all the current from the diodes.
You might be able to make it work with a nodeset for the PMOS gates = 0V. It might also work if you inject a small current into node "A" to make sure it isn't in the 0 state and increase Av from 1e3 to 1e5. But I think you'll need to figure out a startup circuit before you'll be able to simulate -- assuming one exists.
Alberto
Analog Circuit
Designer
Mexico
Reply #18 - Oct 20th, 2013, 2:46am
RobG wrote on Oct 19th, 2013, 9:40pm:
Thanks RobG i will test that solution, the BG reference exists, in a master thesis. I will be working in this issue and I will comment the results.
Alberto
Analog Circuit
Designer
Mexico
Reply #19 - Oct 21st, 2013, 3:36am
Hi RobG you were right the nodes to apply node set are: node A and the gate of the PMOS. That's all, That band gap circuit does not have the problem of the "I" drop in the parallel resistors of the diodes because they are big, more or less 1MOhm each.
Thank so much for your help. I'm attaching the result.
RobG
Bozeman, MT
Reply #20 - Oct 21st, 2013, 7:32am
Glad I could help.
Is that circuit published?
Alberto
Analog Circuit
Designer
Mexico
Reply #21 - Oct 21st, 2013, 8:55am
RobG wrote on Oct 21st, 2013, 7:32am:
Glad I could help.
Yes It is, It was published by Gupta student of Phillip Allen
RobG
Bozeman, MT
Reply #22 - Oct 21st, 2013, 9:29am
I couldn't find it. Do you have the year and publication?
I assume the resistor divider + diode circuit is a Thevenin equivalent of a Vbe/2 diode with a series R of R2/2.
Alberto
Analog Circuit
Designer
Mexico
Reply #23 - Oct 21st, 2013, 9:51am
RobG wrote on Oct 21st, 2013, 9:29am:
I will send you and email please check it
Pages: 1 2
