Aug 3rd, 2024, 7:22am
low power current starved  ring oscillator (Read 5439 times)
mixed_signal
Jun 30th, 2012, 2:07am
I am designing a low power current starved ring oscillator as shown in attachment. The bias current for each inverters is in the range of 50n to 100nA.
M1 M4 are in strong inversion saturation and act as current sources. i have made w/l very small like 1/40 to put them in strong inversion.
How do i size M2 M3? If i size for general  inverter like 4/1 and 2/1 then they will be in weak inversion during switching at such low currents. Is that OK?
OR should i size them with w/L small so that the are in strong inversion?
AnalogDE
Re: low power current starved  ring oscillator
Reply #1 - Jun 30th, 2012, 11:43am
M2 and M3 are just switches.  They will be in linear operation region of operation for the most part.  Start with min-L and wide enough so the voltage drop across them is small enough to keep the outer devices in saturation.
mixed_signal
Reply #2 - Jun 30th, 2012, 8:14pm
If w/l of M2, M3 is made greater than 1 then at current =40nA they will be in weak inversion. Isnt it a problem? To put them in strong inversion w/l of all transistors have to be <<1
AnalogDE
Reply #3 - Jul 1st, 2012, 10:09am
The goal in sizing the switches is to minimize Vds.  You may also want to minimize the gate cap of the switches (minimize loading).  All this necessitates a min L device with the smallest W that works for you.
Reply #4 - Jul 3rd, 2012, 2:57pm
what is this for?
THis type of architecture is very noise sensitive (power and ground) and full of jitter problems in a VCO ring oscillator PLL.
mixed_signal
Reply #5 - Jul 3rd, 2012, 10:16pm
Hi loose-electron,
This is for an ultra low power temperature sensor. I found this vco frequenc to be highly linear wrt bias current. I like it!!!!
I want to do a transient simulation for the vco and at the same time sweep temperature during the transient. How can it be done in cadence?
Reply #6 - Jul 4th, 2012, 7:36am
Hi mixed-signal,
Please look at
http://www.designers-guide.org/Forum/YaBB.pl?num=1275773203/1#1
for changing temperature during a transient analysis.
Yawei
Reply #7 - Jul 7th, 2012, 8:58pm
mixed_signal wrote on Jul 3rd, 2012, 10:16pm:
Hi loose-electron,
Put some impedance in the power and ground, and put some noise on both.
You may not like it so much after that.
mixed_signal
Reply #8 - Jul 8th, 2012, 9:02am
Hi loose electron,
I m interested in the simulations suggested. But how do u put impedance & noise in cadence? Can u explain ? Smiley
