Aug 5th, 2024, 3:18am
Pages: 1 2
Output Impedance of circuit (Read 10144 times)
aaron_do
Re: Output Impedance of circuit
Reply #15 - Jul 06th, 2012, 9:18pm
NMOS devices are much faster, so you can definitely get a wider bandwidth. lower power consumption, lower input inpedance, more gain or whichever you choose. However, I believe they suffer from poorer flicker noise performance. So if the signal you are sensing has a narrow bandwidth, then PMOS "may" be better.
pf66
Reply #16 - Aug 8th, 2012, 8:35am
Dear Larry,
MB PMOS is loading your output node with it's gate cap, try to minimize it's W*L, in order to maintain the same DC point + Loop gain, use smaller Rb (trade-off is power, of course).
BTW, why not  use Ib instead of Rb?
Pages: 1 2
