Aug 3rd, 2024, 7:18pm
How much capacitance as the load for this closed loop Opamp? (Read 894 times)
Jacki
Jul 03rd, 2012, 10:09am
   I have a question about the driving ability as shown in the figure below,
   Capacitor Ca is the negative feedback loop and capacitor Cx is the positive feedback loop. When I design the OTA, how many capacitors I should take as the load, is it only Ca, or it should be Ca+Cx, or it is something else? Could anybody give me some comments?
   Thanks.
aaron_do
Re: How much capacitance as the load for this closed loop Opamp?
Reply #1 - Jul 3rd, 2012, 5:59pm
For common-mode, the capacitances add, but for differential mode they subtract.
Jacki
Reply #2 - Jul 4th, 2012, 1:04am
Hello aaron_do,
   Thank you very much!
   Jacki
Jacki
Reply #3 - Jul 4th, 2012, 4:58am
   I have another question, how about the noise analysis for Ca and Cx. Consider it operates at a sampling and hold system. At the sampling phase, both Ca and Cx are sampled, and at the hold phase, the connection for Ca and Cx are shown in the figure above.
   Thanks.
   Jacki
BackerShu
Reply #4 - Jul 18th, 2012, 9:23pm
An interesting question.
It seems to me that for noise analysis input should be assumed to be AC ground. In this way, it should be Ca+Cx.
But is the input of the whole stage the same as the input of the OTA?
