Aug 3rd, 2024, 5:18pm
Extremely low power inverters (Read 3210 times)
mixed_signal
Jul 13th, 2012, 9:29am
I am designing a buffer using a simple inverter at the o/p of a vco. The switching current should be<1uA since max available is 3uA. For this I have to size PMOS as 1u/40u and NMOS as 250n/40u. Will this extremely less w/l cause any problems? The supply is 1.2V.
The O/P has slight spikes at the transition points.
boe
Re: Extremely low power inverters
Reply #1 - Jul 17th, 2012, 9:13am
Mixed_signal,
L=40u? What is your load? f=?
- B O E
mixed_signal
Reply #2 - Jul 17th, 2012, 10:09am
It is the O/P. I may feed it to FPGA for further processing so it has to go through level converters. Frequency is in khz i.e. 15khz
boe
Reply #3 - Jul 17th, 2012, 12:05pm
Mixed_signal,
a few questions/hints:
Is your current requirement for I_peak or I_avg?
Is the transistor model realistic for L=40u?
Did you include the (external) load in your simulation?
What is the rise/fall time with ext. load? How does the load react to that?
- B O E
mixed_signal
Reply #4 - Jul 18th, 2012, 1:14pm
My current requirement is for peak current=3uA. My average current is 300nA.
I m not sure about the models. i m using ibm130cmrfsf8.
I did not add any  external load in simulation.
mixed_signal
Reply #5 - Jul 18th, 2012, 2:01pm
I will have a series of scaled inverters to match my load. Besides, I want to know how do you layout a 2u/40u device. Does fingering with 1u/40u make sense.
I have seen people in forums talking this issue for ultra low power circuits but with varied opinion. Some say to go for fingering , some say for length fingering or stacking and some ask not to go for such lengths!! Smiley
