Sep 16th, 2026, 8:07am
wafer probing with die on PCB (Read 2748 times)
aaron_do
Jul 04th, 2012, 6:21pm
I have a design where the input port needs to be probed directly on the wafer, while the output should be from an SMA port on the PCB.
Is it possible to probe a die which is already soldered onto a PCB? My main concern is whether the plane of the die will be horizontal enough for proper probing. If you have any experience with this please share.
thanks,
Aaron
