Jul 17th, 2024, 3:26am
PSTAB analysis spectre (Read 2062 times)
DDC
Jul 10th, 2012, 7:20am
I want to set up a pstab analysis in spectre rf for a downconversion mixer. I have a common mode feedback and I want to see phase margin. Have I to apply a extra source with a pac magnitude or is it enough to insert the iprobe instance in the feedback loop ? Thanks for response.
Frank Wiedmann
Munich, Germany
Re: PSTAB analysis spectre
Reply #1 - Jul 11th, 2012, 1:22am
It is sufficient to insert the iprobe instance, you do not need an extra pac source. The pstb analysis computes the loop gain of the zero sideband, so you should insert the iprobe at a place in the loop where you have an unmodulated (baseband or dc) signal.
