May 7th, 2024, 5:08pm
Unrealatic simulation of Fmax for IBM90nm in cadence (Read 1776 times)
nadroit
Jul 12th, 2012, 8:49am
Hello All,
 I am trying to measure Fmax of IBM 90nm technology in cadence. I am measuring S parameters and plotting Gumx. I get Fmax around 500GHz for 90nm while reported Fmax for 90nm are around 300GHz. I am using rfmos transistor & technology uses BSIM4.4 model. I am not sure what I am doing wrong please help.
Re: Unrealatic simulation of Fmax for IBM90nm in cadence
Reply #1 - Jul 18th, 2012, 10:01am
Are you including any layout parasitics?  The metal stack that's needed to connect to the device can add a lot of capacitance, which may not be accounted for in the rfmos model.
