jeffrey-peng
when run mixed signal design using bsimsoi4.3 model, the irun.log says "Model parameter version =4.3 is not valid, reset to default model value = 3" and the simulator doesn't convergence.
when run print_mmsimver in shell the spectre version is 7.1.1
does any one know how to fix this problem?
