Apr 26th, 2024, 8:44am
Does AMS support bsimsoi4.3 model (Read 3893 times)
jeffrey-peng
Jul 20th, 2012, 2:05am
when run mixed signal design using bsimsoi4.3 model, the irun.log says
"Model parameter version =4.3 is not valid, reset to default model value = 3"
and the simulator doesn't convergence.
when run print_mmsimver in shell
the spectre version is 7.1.1
does any one know how to fix this problem?
Re: Does AMS support bsimsoi4.3 model
Reply #1 - Jul 20th, 2012, 11:52am
Get a newer version of spectre -- yours is a few years old.
