Jul 2nd, 2025, 8:45am
AC Coupling cap with different values (Read 1427 times)
supermoment
Aug 01st, 2012, 11:26pm
Hi
I tested  5Gbps Tx driver with different ac coupling cap value, 4pF & 100nF with 100ohm differential termination. The waveforms are as below:
When the ac coupling cap is 100nF, the differential signals are shifted, is it normal or something wrong?? for PCIe2 , the coupling cap is around 65-200nF right?
Re: AC Coupling cap with different values
Reply #1 - Aug 26th, 2012, 1:11pm
They are phase shifted in both cases.
Basic network theory - Whats the impedance you are coupling into?
supermoment
Reply #2 - Aug 26th, 2012, 8:06pm
i know the reason already.
it is due to the initial simulation condition, where the nodes are not settle down yet.
