Jan 13th, 2026, 5:22am
Resistor Modeling with look up table approach (Read 6783 times)
Ganesh70508
Mumbai
Aug 11th, 2012, 7:01am
I want to design a simple resistor in verilog-A i used following verilog code
`include "constants.vams"
`include "disciplines.vams"
module Table_NL_Resistor(a,b);
inout a;
inout b;
electrical a,b;
parameter real k = 0 from [0:inf);
analog begin
     V(a,b) <+ k*$table_model(I(a,b),"sample.dat");
i tried to simulate above model in cadence spectre it works fine when i connect current source in series with above resistor. Voltage and current Waveform appear properly after simulation
but while simulating using Voltage source in series with above element no Waveform shows up at the output.
how do i overcome above limitation ...?
how can i model such elements in verilogA using look up table based approach ..?
plz Suggest
Thank You,
Ganesh
Smiley
boe
Re: Resistor Modeling with look up table approach
Reply #1 - Aug 13th, 2012, 10:15am
Ganesh70508 wrote on Aug 11th, 2012, 7:01am:
... but while simulating using Voltage source in series with above element no Waveform shows up at the output.
plz Suggest
See http://www.designers-guide.org/Forum/guidelines.html
- B O E
