Jul 17th, 2024, 1:27am
Technology for low power biomedical transceiver (Read 2402 times)
mixed_signal
Aug 24th, 2012, 1:42pm
I am going to design a low power biomedical transceiver for wireless body area network. Most of the papers in this field use 130nm technology. But I have no idea how technology impacts low power radio. Can anyone help /cite references to choose the proper technology?
I understand that low power radio needs high Q inductor and hence people often go offchip or process which provides high Q inductors.
Re: Technology for low power biomedical transceiver
Reply #1 - Aug 26th, 2012, 11:09am
going to need a lot more specifics before anyone can help you.
A lot of RF under 3GHz  is designed in 130 - 180 nm technology.
aaron_do
Reply #2 - Aug 26th, 2012, 10:53pm
Choice of technology often comes down to the cheapest technology which can do the job. Also, there are a lot of factors involved, so an older technology node isn't necessarily cheaper than a newer one.
For your application, you may find that you don't need such high-Q inductors.
regards,
Aaron
