Aug 14th, 2024, 3:21am
need help..... search for voltage regulator (Read 1632 times)
rafa
Sep 11th, 2012, 11:40pm
hi
can anyone let me know of a voltage regulator which produces a constant 2.5V regulated output when handling input ranging 2.5V-3V. it should be able to deliver around 50mA output current
aaron_do
Re: need help..... search for voltage regulator
Reply #1 - Sep 12th, 2012, 1:46am
Check something like digikey. I'm in Singapore, and I use element14.com.
Aaron
Reply #2 - Sep 18th, 2012, 8:03pm
You want what is called a "LDO Voltage Regulator"
Digikey or similar for possibles.
However you will not get 2.5 volts out of a regualtor on a 2.5v supply.
Close, but there will be some "drop out" voltage loss.
Maybe maintain 2.5 with the power supply as low as 2.55 or similar.
