Best Design Tool = Capable Designers
You want what is called a "LDO Voltage Regulator"
Digikey or similar for possibles.
However you will not get 2.5 volts out of a regualtor on a 2.5v supply.
Close, but there will be some "drop out" voltage loss. Maybe maintain 2.5 with the power supply as low as 2.55 or similar.
