Oct 19th, 2024, 3:02pm
osc reference voltage problem (Read 2708 times)
lhlbluesky_lhl
Sep 28th, 2012, 6:18am
in osc.jpg, it is the diagram of my osc, the voltage in CL(assuming node VI) is a ramp wave, but in simulation, i found that, the voltage of Vref1 and Vref2 is also changed with VI(ripple is about +/- 10mV), the amplitude is about 2% of VIpk-pk, i guess it is due to the capacitive coupling. and if i increase C1 and C2, or decrease the input pair size of comparator, the ripple in Vref1 and Vref2 decreases too. if i want to make Vref1 and Vref2 stable(ripple as small as possible), and not using very large C1 and C2(for area saving), not using very small input pair size for comparator(for good matching), is there any solution or method?thanks all for reply.
rfidea
Europe
Re: osc reference voltage problem
Reply #1 - Sep 28th, 2012, 8:43am
Try to understand the coupling mechanism in the comparators and then decrease it.  :) Really, it is very hard to give a good answer if you do not show the comparator design.
lhlbluesky_lhl
Reply #2 - Sep 29th, 2012, 5:12am
the comparator is non-compensated two-stage opamp plus inverter, and the input pair size is large(w*L=50u^2) for matching consideration. any advice or ideas?
besides, the power supply of osc is provided by a internally compensated LDO. thanks.
Reply #3 - Oct 2nd, 2012, 4:45am
put a resistance in series with the comparator inputs that is coming from the ramp signal.
You are getting capacitive voltage division across the differential input pair of the comparators
analog_wiz
Universe
Reply #4 - Nov 21st, 2012, 7:59pm
I would suggest using minimum possible length for input transistors,for 0.18u use 0.25u, it will reduce the parasitic capacitances and reduce coupling hence. One more point, although you maybe seeing a ripple, is it actually affecting output frequency accuracy. It could be that everytime during comparator comparison this may occur, but the comparator will have already compared against vref and this vref+delta might not actually affect you. Just run across corners and let us know.I believe you are using too large input transistors.You will need to reduce input sizes drastically from WL=50what is comparator bias current, less than 10u?Also please let us know what output accuracy you are trying to meet and the output frequency of the oscillator.
