rfidea
Do you want to to something like i = exp(exp(K*time)) ?
I think there is a "exp()" block in the ahdlLib. If you create a voltage slope, v = K*time with the vpulse from analogLib and then drive two series connected exp blocks from ahdlLib it will do the trick.
