Aug 16th, 2024, 7:45pm
Double exponential current source (Read 1067 times)
Annie
Sep 29th, 2012, 4:27am
Is there any way to provide a double exponential current source in CADENCE IC5.1.4.1? I want to test the SEU tolerance by injecting current spike,no TCAD simulator available...any help?
rfidea
Europe
Re: Double exponential current source
Reply #1 - Sep 29th, 2012, 4:59am
Do you want to to something like i = exp(exp(K*time)) ?
I think there is a "exp()" block in the ahdlLib. If you create a voltage slope, v = K*time with the vpulse from analogLib and then drive two series connected exp blocks from ahdlLib it will do the trick.
Annie
Reply #2 - Sep 30th, 2012, 2:17am
Actually, I meant something like a spike with different rise and fall time like
I(t)=A/(Tf-Tr){exp(-t/Tf)-exp(-t/Tr)}.
Is it possible to do with Iexp in AnalogLib?
boe
Reply #3 - Oct 2nd, 2012, 12:13am
Annie,
did you try it?
- B O E
