kamath
Hi All,
I have a circuit whose node voltage is being saved into file in Virtuoso.
I am able to open a file and store the same. The problem is when I run a parametric sweep of a given variable lets say x=1:10, I get all the data into one single file. i would ideally want a file dataX.txt where X is 1:10 for each run.
I checked the concatenation method in Verilog-A and been able to reach until a point where i am unable to find the right typecasting for X. Is there a way to do this to string from integer in verilog-a.
Regards Kamath
