Jul 18th, 2024, 3:38am
Pages: 1 2
properties of stacked mos device (Read 714 times)
yvkrishna
Oct 13th, 2012, 2:24pm
Hi everyone,
In shorter geometries as the max lengths get limited people started using stacked mos devices to increase effective length(mosfets in series to increase the length analogous to mos in parallel for increasing total width)
Is there any basic reference document for understanding the properties of this composite device (series stack) like effective vth,vdsat, parasitics, mismatch,noise etc.
Ex: W/L  in series with W/L is equivalent to device of W/2L dimensions.
--To a first order we expect this composite device behaves like a single device with effective length of 2X, is it true for all properties of device?
-- can we really use devices of different lengths ?
is W/L1  stacked with W/L2   equivalent to  W/(L1+L2)??
yvkrishna
raja.cedt
Re: properties of stacked mos device
Reply #1 - Oct 15th, 2012, 7:45am
hello,
1. yes, when you have W1/L1 and W2/L2 size transistors the resulting
transistor size from DC characteristics point of view L/W=L1/W1+L2/W2.
2. Effective Vt will be same as top transistor.
3.       Coming to  device intrinsic  mismatch up to it is not effective, the normal saying of larger effective length will not work here. Look reduction of mismatch with bigger size comes from the random averaging theory, instead here effectively you are increasing the size.
       Let us model bottom triode transistor as a resister (for now assume there is no modulation of resistance due to drain voltage variation). In the contest of  degeneration mismatch of the top transistor will be reduced but  resister mismatch will introduced, however resister matches better but here this resister emulated by again Mosfet.
4. Noise is worse, because same reason mos noise worse than degeneration.
So bottom line is this combination will be good from low voltage operation point of view and may be worse from other aspects.
raj.
yvkrishna
Reply #2 - Nov 27th, 2012, 8:02am
Thanks raja for your inputs.
1.Yes  L/W =L1/W1 +L2/W2
3. But for mismatch I could very well correlate my monte simulation results with a device of effective length and wdith (sim matches well for nmos/pmos across various sizes, bias , number of stacks etc)
yvkrishna
rfidea
Europe
Reply #3 - Nov 27th, 2012, 11:26am
I agree with raja that in principle you can add the two lengths. But I wonder why you would like to stack two devices. I would have increased the length and only use one transistor. Usually there is some limitation in the design kit, but that is the length need to be shorter than some 25 um or so.
yvkrishna
Reply #4 - Nov 27th, 2012, 11:35am
@rfidea,
Here I am talking about advanced process nodes with max length not even 5um.
rfidea
Europe
Reply #5 - Nov 27th, 2012, 1:19pm
Aha, I did not know that Lmax was that low for those processes. I do not understand why, though. Is there any technical reason other than logistical such as testing and modeling efficency.
raja.cedt
Reply #6 - Nov 27th, 2012, 2:54pm
hello vamsi,
I didn't have ans for mismatch reduction. Whats your simulation setup, have you observed noise reduction simply by replacing mosfet by stacked mosfet? or any modification. If this is the case then  realizing good cascoding with lesser voltage head room could be posb, try to use this.
Thnaks,
Raj.
analog_wiz
Universe
Reply #7 - Nov 27th, 2012, 7:19pm
I dont think there is any limit on the length say 5u in smaller gomentries. The only time i use devices in series is to get some very small current mirrored eg:1/2:1/8 (1/8=four 1/2 devices in series).
« Last Edit: Nov 27th, 2012, 9:41pm by analog_wiz »
Lex
Eindhoven, Holland
Reply #8 - Nov 28th, 2012, 12:59am
Max 5um length is surely a modelling 'thing'.
However for some other layout topologies (such as ELT), there is no other choice than stacking since naturally you have a large effective W/L.
raja.cedt
Reply #9 - Nov 28th, 2012, 6:44am
@ analog_wiz,
Can you please explain clear why did you use stacked devices?,i were you i would have done  2:1 mirroring directly rather than using stacked devices, up to me stacked device is equivalent to larger length device, but up to me mismatch will be bad for this combination.
Did you find any reduction in the noise or mismatch, because  yvkrishna noticed reduction in mismatch i just want to check is it consistent with every one.
@Lex  : i heard mainly fabrication limitation due to introduction of Double-pattern lithography metal gate technologies in lower technologies and orientation limitation due to modeling(i am not sure) . What is ELT?
Raj.
Lex
Eindhoven, Holland
Reply #10 - Nov 28th, 2012, 8:13am
@raja.
An ELT MOSFET is where you have the gate completely surrounding the drain. Here is a simple diagram:
raja.cedt
Reply #11 - Nov 28th, 2012, 8:42am
hello Lex,
interesting, this i knew this with name donnet transistor, but haven't seen in any technology.Which foundry is providing this?
Raj.
carlgrace
Berkeley, CA
Reply #12 - Nov 28th, 2012, 9:06am
raja.cedt wrote on Nov 28th, 2012, 8:42am:
hello Lex,
Raj.
You can make an ELT in any process you just have to lay it out by hand (it won't be included as a pcell in the pdk).  You probably have to do a test chip to characterize their performance if you have critical requirements in your application.
They are primarily used for radiation hardness as they are more tolerant of total dose radiation than standard layouts.
yvkrishna
Reply #13 - Nov 28th, 2012, 9:38am
analog_wiz
Universe
Reply #14 - Nov 28th, 2012, 10:15am
i used devices in series to generate very less current: say i have 1u through (1u/2u)transistor  and i need to generate 1/4 the current, then i would use (1u/2u) four of them connected in series. Would be interested in hearing if there were any other better methods of generating very low current from a given current.
Pages: 1 2
