Aug 17th, 2024, 12:32pm
Why Vth decrease with larger channel length in modern CMOS? (Read 2055 times)
neoflash
Mixed-Signal
Designer
Mar 26th, 2013, 10:35pm
If we plot the Vth versus channel length, we will notice Vth first increase when channel length is close to Lmin, then Vth slowly decreases with larger L.
Why Vth will get smaller with larger L?
raja.cedt
Re: Why Vth decrease with larger channel length in modern CMOS?
Reply #1 - Mar 27th, 2013, 12:45am
this indeed depends on the foundry and will not be consistent for all. According to short channel effect when channel length getting smaller and small amount of charge will be created from drain and source diffusion, due to this Vth reduced. So smaller length smaller the vth. To combat this Vth reduction people use pocket hollows in the channel. Ideally this should make Vth flat across all the lengths but some time it might over compensate also, means Vth slightly increase with channel length up to some extent .
Raj.
