Jul 18th, 2024, 3:25am
Pages: 1 2
properties of stacked mos device (Read 706 times)
rfidea
Europe
Re: properties of stacked mos device
Reply #15 - Nov 29th, 2012, 12:35pm
One solution is to use four transistors in parallel of W/L=1u/8u as reference transistor with 1uA and then one 1u/8u transistor for the 1/4 uA transistor. Larger layout but probably better matching.
analog_wiz
Universe
Reply #16 - Nov 29th, 2012, 11:35pm
But will it not be bad in the sense that the vth of a 1u/8u and 1u/2u device will not be the same and will lead to a systematic current mismatch error?
rfidea
Europe
Reply #17 - Nov 30th, 2012, 1:38pm
Not if you implement the 4x 1u/8u transistor as four unique transistors. Then the current density of each of them will be the same as the single 1u/8u, which give the same vth and good matching.
raja.cedt
Reply #18 - Dec 2nd, 2012, 5:14pm
hello rfidea,
i guess Vth mismatch will be serious problem in this case. How current density related to Vth (from your previous post).
Raj.
rfidea
Europe
Reply #19 - Dec 3rd, 2012, 11:29am
Of course, for the specific current the W/L ratio needs to be chosen so the Vgs-Vth voltage is high enough to get the wanted Vth mismatch.
threepwood
Reply #20 - Mar 23rd, 2013, 6:39am
Interresting topic
Can someone provide mathematical calculation to prove it?
I would extend the question for robust cascode polarization technique below:
I know it works fine, but I've never managed to calculate why. I also think that the 2 (or 3, or 4,...) devices at the bottom (that are in triode region) must match the NMOS bias device...
Can someone try to do the calculations?  :)
English is not my mother tongue, so please excuse my mistakes ^^
Horror Vacui
Dresden, Germany
Reply #21 - Mar 23rd, 2013, 12:51pm
I doubt whether any calculations should give you a good enough precision. Nowadays the square law MOS characterisitc is far from precise and also you will have one transistor in saturation and all the other in triode region not far from the saturation region.
Horror Vacui
Dresden, Germany
Reply #22 - Mar 23rd, 2013, 12:52pm
threepwood
Reply #23 - Mar 23rd, 2013, 1:08pm
Horror Vacui wrote on Mar 23rd, 2013, 12:51pm:
They are all deeply linear (with VDS=5,10,15mV,..) and the device at the top, even if the square law is not accurate, I just would like to get a trend
Pages: 1 2
