Aug 31st, 2024, 11:23pm
BOOST "DUTY CYCLE" ISSUE (Read 3574 times)
A Kumar R
India
Nov 04th, 2012, 1:54am
I want to intuitively understand why the "Duty" in a typical inductor-based DC-DC BOOST converter depends "quadratically" on the parameters like Output Voltage, Input Voltage, Losses..etc...
Mathematically, it is clear to me. But, Why should there be a second-order dependency in this converter, unlike in BUCK Converter?
Thank you..
sushan
Re: BOOST "DUTY CYCLE" ISSUE
Reply #1 - May 6th, 2013, 4:21am
I guess intuitively the average current supplied to the output is a strong function of the duty. And same is the case for the 'equivalent resistance' offered by the inductor. So, the quadratic relation comes. Please correct me if I'm wrong.
A Kumar R
India
Reply #2 - May 8th, 2013, 9:18am
Hi Yuvan,
Thanks for the reply.
Anyways, i didn't understand what you were trying to say.
Can you please elaborate a bit?
Thanks...
Anil Reddy
