Jul 28th, 2024, 5:31pm
8 bit SAR ADC DAC capacitive array! (Read 457 times)
Sx_cut
Dresden, Germany
Nov 17th, 2012, 2:28am
Dear readers!
I am designing SAR ADC for the first time and have a little problem in designing binary weighted capacitive array for the DAC. I am using a unit capacitance of 8fF. My input signal voltage range varies from 0 to 1V but my capacitive array only covers signals upto 600mV. I have tried changing the ref voltage and the value of capacitors but to no avail. I have attached a figure which shows each bit setting to high value in an  8 bit ADC. When all bits are set the amplitude I am getting is 0.6V. What is that I am missing!
Re: 8 bit SAR ADC DAC capacitive array!
Reply #1 - Nov 19th, 2012, 8:36pm
Capacitance sounds a bit small - May be losing some signal due to
parasitic capacitance.
can you post a schematic of the circuit you are using?
