Jul 16th, 2024, 11:27pm
Coupling LNA with passive mixer. (Read 4549 times)
milvapp
Dec 06th, 2012, 2:00am
Hello,I have designed a simple sinlge-output LNA and I would like to connect to a current-driven single-balanced passive mixer.
Considering the I path only what defines the value of the coupling capacitance?Is there a formula ?
I would like to add that the mixer is 50% duty cycle.
Thank you in advance!
Leo.cd
Re: Coupling LNA with passive mixer.
Reply #1 - Dec 22nd, 2012, 8:26pm
make the LNA and Mixer conjugate match, make sure u deliver the max power.
milvapp
Reply #2 - Dec 24th, 2012, 2:23am
Can you explain how to achieve maximum power transfer with the capacitance divider?
Thank you.
vivarf
Reply #3 - Feb 17th, 2013, 5:46pm
You want to maximize the current from LNA to current-driven single-balanced passive mixer. I assume your operating freq is under several GHz, so the coupling capacitance simply resonates with the output load inductance of the LNA.
View Profile veeater   IP Logged
milvapp
Reply #4 - Feb 18th, 2013, 2:11am
Hi vivarf,thanks for the reply.
As I am new to this,can you explain why it should resonate with the LNA load?(Yes the baseband frequency is around 10Mhz while the RF freq is 2.5Ghz
vivarf
Reply #5 - Feb 18th, 2013, 3:00am
Basically you want to maximize the current go to the mixer. You may want to take a look at the IEEE paper by Mirzaei about receiver/current mixer. Sorry I forgot the name of the paper.
vivarf
Reply #6 - Feb 18th, 2013, 6:08pm
milvapp wrote on Feb 18th, 2013, 2:11am:
You want to take a look at this paper by Mirzaei, it quite complex analysis.
"Analysis and Optimization of Current-Driven Passive Mixers in Narrowband Direct-Conversion Receivers"
Cheers
milvapp
Reply #7 - Feb 19th, 2013, 1:46am
Thanks,I ve already looked at this paper and the main explanation is by mathematics,in attempt to maximize the gain.However what is worrying me is that the resulting coupling capacitcance has a quite small value(approx 200 fF)which is not what I waqs expecting.I mean a large capacitor with small impedance,in order not to lose signal.
