Aug 14th, 2024, 11:23am
transient/pss simulations with parasitic extracted netlist (Read 5819 times)
analog2000
Dec 30th, 2012, 1:05pm
I have a switched cap 4th order low pass filter which is differential in nature.
I can do transient/pss/pxf simulations without any problem on a netlist generated from a schematic.
However, I do not see any meaningful outputs when I try to simulate the same circuit using layout extracted parasitics (R+C).
The # of nodes is 31174, # of bsim3v3 is 2881, bourse_1 is 755, capacitors is 50100, resistors are 40022.
With this size netlist, the transients and the pss simulations do not start properly. The opamp outputs hit the rails, the moment the clocks start.
I read spectre.ic from readic menu, I use +parasitics and +csfe to minimize the # of parasitics.
Any help will be greatly appreciated
thanks
analog2000
rfidea
Europe
Re: transient/pss simulations with parasitic extracted netlist
Reply #1 - Dec 30th, 2012, 1:29pm
Two simple questions.
Does the DC operating point looks ok in the extraction sim? Specially the outputs from digital gates if you use such devices as clock drivers.
Is the layout LVS clean?
analog2000
Reply #2 - Dec 30th, 2012, 2:31pm
I am setting the initital conditions with a spectre.ic file that I created when doing transient on the schematic based net list earllier. I am setting skipdc=yes to force the simulator to use the ic on all relevant nets so dc op should not be necessary to run
Yes, the layout is lvs/drc clean
analog2000
rfidea
Europe
Reply #3 - Dec 31st, 2012, 1:23am
Both pss and tran is doing a DC analysis before the actual transient analysis starts. The initial conditions is only used to set the initial "guess" for that DC analysis.
My idea about looking at a DC solution is to see if your circuit behaves as expected in DC. It not, there is some mayor fault.
