Dec 7th, 2025, 10:36am
SC Amp PSS/PNOISE Noise simulation using jittery clock and noisy power-supply (Read 3842 times)
Akbar
Feb 06th, 2013, 7:09am
Hi All,
I need to do SC Amplifier PSS/PNOISE Noise simulation using jittery clock and noisy power-supply/common-mode/diff-input signal to check the noise folding due to mixing at output of SCA at relatetively low frequency (<100Hz). My clock speed is around 125MHz.
My questions are following:
1. Is it possible to do so independent of simulator?
2. If it is possible, using spectre-RF+APS, do i need any special testbench setup or just usual PSS/PNOISE setup (including input source port and output probe instance) is fine.
Akbar Momin
