Aug 18th, 2024, 7:26am
BGR correctness (Read 3557 times)
james_lanren
BGR correctness
Jan 04th, 2013, 1:52am
I have designed a bgr which has an output voltage against temp as follows. The output voltage is 1.15 instead of 1.205. Will it be tolerable?
Also the curvature is upward facing, is that correct?
yvkrishna
Re: BGR correctness
Reply #1 - Jan 4th, 2013, 8:01am
Hi James,
I assume this is simple BGR design without any curvature compensation used.
o/p voltage will not exactly be 1.205 for every process(depends on lot of things) but usually close it if you design a classical voltage bandgap.
Tolerance is always about the total variations with PVT, absolute value is usually easy to trim and control.
And about curvature facing upwards, it might be to do with the BJT used, did you try to observe if BJT alone has proper temperature characterless.(CTAT nature)
use a different bjt/diode and double check.
you can post your schematic for better replies to your queries.
yvkrishna
Dan Clement
Salt Lake City, Utah, USA
Re: BGR correctness
Reply #2 - Jan 4th, 2013, 10:34am
This can be normal, it just depends on the tempcos of resistors, offsets, etc.
It could also be a sign that your collector current is too high...
Re: BGR correctness
Reply #3 - Jan 12th, 2013, 4:11pm
suggest posting the schematic. Also have you modeled in you mismatches and offsets? Those can throw the accuracy off a lot more than the tempco variance.
analog_wiz
Universe
Re: BGR correctness
Reply #4 - Jan 14th, 2013, 4:56am
Have you checked the leakage of the startup circuit at high temp?
RobG
Bozeman, MT
Re: BGR correctness
Reply #5 - Feb 5th, 2013, 1:28pm
A bit late, but something is very messed up. Your curvature is 75 mV and upward. 4 mV and downward is typical.
Erez_Sarig
Re: BGR correctness
Reply #6 - Feb 7th, 2013, 1:04pm
It looks like you are very close to fine tune the BGREF your PTAT is too high so decrease it and you should get a better level.
Best thing to do is to take aside the BJT and using ideal devices see the real ratio of PTAT and CTAT. also measure the PTAT which should be around 166uV/C.
Still it is hard to conslute without seeing the schematic....
Erez
