Aug 18th, 2024, 5:23am
regulator stability (Read 3120 times)
james_lanren
regulator stability
Jan 21st, 2013, 12:40am
I have designed a linear regulator with a two-stage amplifier with an nmos  driver. I used miller capacitor and a nulling resistor for compensation at the second stage. I also checked the frequency response and the phase margin are quite good (90 deg and even more) across different load current (max ~1mA). However, when I did a transient sim at a particular load current (200uA), I saw oscillation at the output. It puzzles me becoz the frequency response satisfies the stability criteria at that load current.
Could the miller compensation make the second stage a potential oscillation source? Should I separate it from the first stage and output to check its stability? Any idea to overcome?  Thanks
raja.cedt
Re: regulator stability
Reply #1 - Jan 21st, 2013, 1:08am
1. You have to check stability at lower current because regulator output pole (~gm2/CL) will be near to UGB or some cases even below. Please check this and post result whenever you want some good answer in short time.
The above statement will be useful only if your second pole is non-dominate.
2.Some time phase margin may not guarantee stability due to non-monotonicity in the bode plot. In that case either you have to use Nyquist plot (tough for an ckt designers) or pole zero analysis on closed loop and last but and best case transient.
Raj.
AS
US
Reply #2 - Jan 22nd, 2013, 5:32pm
For a NMOS driver i.e. power device, the O/P impedance is maximum at minimum load current condition. The dominant pole is located at the first stage of amplifier/the non-dominant poles are located at amplifier output and load. You want to test your stability in the zero-load-current condition to simulate the worst-case. This is unlike the case for a PMOS power device, where peak current is the least stable bound.
-Aman
raja.cedt
Reply #3 - Jan 23rd, 2013, 1:33am
hello Aman,
i don't think worst case will be differ for pmos and nmos. Because in case of pmos second pole depends on gds2/CL which is directly depends on current, where as in case of nmos second pole depends on gm2/CL which is also depends on directly on current. Correct me if am wrong.
Raj.
AS
US
Reply #4 - Jan 31st, 2013, 5:02pm
Raj,
I guess the answer is a bit tricky and depends on high-frequency PSRR i.e. compensation design. Generally speaking in PMOS driver designs dominant pole is located at the output, which is not the case in NMOS driver type designs. So, for a NMOS driver LDO the dominant pole at error amplifier remains somewhat fixed and the parasitic/secondary pole O/P at low currents move close-in. Thus, if you are coming from a PMOS LDO design, worst-case scenarios might get reversed.
-Aman
Erez_Sarig
Reply #5 - Feb 7th, 2013, 1:10pm
If you used Miller with nulling resistor somewhere in the middle of the signal path which means for example between stages you need to check their local loop as well.
Erez
