Aug 18th, 2024, 3:16am
32kHz oscillator design (Read 2776 times)
ic_engr
Feb 05th, 2013, 6:40pm
Folks
i am in the midst of finalizing a topology for xtal oscillator design. The choice I have is either pierce oscillator or differential relaxation oscillaotor with on-chip capacitor.
Apparantly I am having conflicting opinions regards to relaxatin oscillator consuming less current than the pierce.
Any suggestions ?
ic_engr
Re: 32kHz oscillator design
Reply #1 - Feb 8th, 2013, 6:43pm
how accurate do you need the 32KHz for a real time clock?
RC oscillators are not accurate.
Lex
Eindhoven, Holland
Reply #2 - Feb 11th, 2013, 1:41am
Free running RC oscillator (I guess you mean relaxation oscillators) is not accurate indeed. What about one that is injection-locked?
ic_engr
Reply #3 - Feb 11th, 2013, 5:48am
Sorry,
I may have been misunderstood. I am referring to two topologies for crystal oscillator. Not RC vs. Pierce.
Using the crystal at 32kHz, which topoloogy is advantageous for power consumption and start-up time:
1. Pierce oscillator with crystal
2. Differential Relaxation oscillator with onchip C it has cross coupled NMOS with current sources and the crystal is connected across it.
ic_engr
