BangBang
If HSPICE RF gives what is the expected, then two things comes out: 1. The result from SpectreRF HB may be not accpected to us. Or is square source adjusted by Cadence? Do we need trust Cadence's HB for square source? Or need file CCR against SpectreRF HB for square source? 2. For square source, then we have to use Shooting. Since under HB, much error comes out due to FFT of square, so does it for small signal analysis (for example, for phase noise analysis, will it affect phase noise curve? ). Am I right?
-BangBang
