Dear andrew,
Thank you for your prompt answer!
Please find attached to this post:
the input.scs file, the verilogA model of noise, and the simulations results: transient, noise, PSS, Pnoise and noise summary for phase noise.
The Phase noise and its associated noise summary show that there is only Flicker noise contribution to phase noise but there is still 0 slope phase noise and 1/f2 slope phase noise whereas there should be only 1/f slope and 1/f3 slope phase noise !
I hope you have enough informations..
Raphael
SCHEMATIC:
NOISE MODEL (VERILOGA):
DESIGN VARIABLES:
INPUT.SCS:
// Generated for: spectre
// Generated on: Jan 22 10:36:50 2013
// Design library name: raphael
// Design cell name: oscillateur_diodes
simulator lang=spectre
global 0
parameters number_harmonics=20 F=59k max_sideband=20 bruit_blanc=0 \
bruit_flicker=1u ipulse=100n tstab=50m
include "/home/levy/data/librairie_raf/spice/pmbf4393"
include "/home/levy/data/librairie_raf/spice/1N4500"
// Library name: raphael
// Cell name: oscillateur_diodes
// View name: schematic
R7 (net02 ACout) resistor r=1k isnoisy=no
R6 (CAGout net02) resistor r=10k isnoisy=no
R16 (net3 net13) resistor r=40e6 isnoisy=no
R13 (ACout net3) resistor r=50e6 isnoisy=no
I14 (CAGout net02) 1N4500
I13 (net02 CAGout) 1N4500
I15 (ACout net15 net3 V\+ V\-) opamp gain=1e+06 pole_freq=1e+07 \
rin=1.2e+07 rout=10 ibias=0 vin_offset=0 noise=0
I12 (CAGout 0 net02 V\+ V\-) opamp gain=1e+06 pole_freq=1e+07 rin=1.2e+07 \
I41 (0 net15) generateur_bruit noise_generator=bruit_blanc \
flicker=bruit_flicker
I37 (0 net3) isource type=pulse val0=0 val1=ipulse delay=10u rise=1n \
fall=1n width=10u
L1 (net13 net12) inductor l=130.0K isnoisy=no
C6 (net12 CAGout) capacitor c=55.0a
V1 (V\+ 0) vsource dc=8 type=dc
V0 (V\- 0) vsource dc=-8 type=dc
simulatorOptions options reltol=1e-7 vabstol=1e-10 iabstol=1e-13 temp=27 \
tnom=27 homotopy=all limit=delta scalem=1.0 scale=1.0 \
compatible=spice2 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 \
cols=80 pivrel=1e-3 sensfile="../psf/sens.output" checklimitdest=psf
pss ( ACout 0 ) pss fund=F harms=number_harmonics
+ errpreset=moderate tstab=tstab tstabmethod=gear2only
+ annotate=status
pnoise ( ACout 0 ) pnoise sweeptype=relative relharmnum=1
+ start=1e-8 stop=1e8 dec=5 maxsideband=max_sideband
+ augmented=yes annotate=status saveallsidebands=yes lorentzian=no
+ ppv=yes
noise ( ACout 0 ) noise start=1e-9 stop=1e6 annotate=status
subckts info what=subckts where=rawfile
ahdl_include "/data/levy/librairie_raf/resonateurAMS/opamp_MW/veriloga/veriloga.va"
ahdl_include "/data/levy/librairie_raf/resonateurAMS/generateur_bruit/veriloga/veriloga.va"
TRANSIENT:
NOISE:
PSS:
PNOISE:
NOISE SUMMARY:
