Jul 17th, 2024, 7:34pm
Is this OP stable? (Read 1563 times)
kane
HZ
Is this OP stable?
Jan 08th, 2013, 9:52pm
Hi, all.
   I am designing an 10dB BPF. But I find the phase margin of the OP is good at point A but poor at point B.
   If  this BPF is stable?
I think it is stable ? But not very sure.
kane
HZ
Re: Does the OP is stable
Reply #1 - Jan 8th, 2013, 9:52pm
the phase margin of the OP at point B (at the output of the OP)
raja.cedt
Re: Is this OP stable?
Reply #2 - Jan 8th, 2013, 11:11pm
Where did you break the loop?? How did you find Phase margin. Use STB for better results.
Raj.
buddypoor
Bremen, Germany
Reply #3 - Jan 9th, 2013, 12:21am
kane wrote on Jan 8th, 2013, 9:52pm:
You cannot determine the margin at a particular "point".
The phase margin is found by simulating the open-loop response.
kane
HZ
Reply #4 - Jan 9th, 2013, 5:44pm
Thank you ,very much.
Using STB, get the phasemargin is 35. Is that result OK?
« Last Edit: Jan 9th, 2013, 6:44pm by kane »
raja.cedt
Reply #5 - Jan 9th, 2013, 11:22pm
hello,
Please refer basic book on control systems, you need at least 60 if good step Responce is your concern or around 52 (theoretical) if settling time is your concern with small ringing.
Thanks.
Raj
Erez_Sarig
Reply #6 - Feb 7th, 2013, 1:14pm
it looks like your stability test OK. (As long as the input capacitor exists in the schematic for real. it Yes so you have good PM.
Cadence allow you to use STB simulation which do it for you.
Erez
Reply #7 - Feb 8th, 2013, 6:40pm
35 degrees? Too little phase margin in my opinion.
Expect it to ring in the time domain.
Try a time domain closed loop simulation and see how it responds to a step input.
Also, check it over process corners and it will probably be even less.
Also check it with both high and low common mode input too.
threepwood
Reply #8 - Mar 23rd, 2013, 5:45am
Hi, all.
From your Open Loop AC signal ( called OL(s) )
Create a formula in your calculator: CL(s) = OL(s) / ( 1+OL(s) ) and probe the amplitude in dB20 of this complex expression. If you see any overshoot somewhere, you can consider your circuit is not robustly stable, and if you see a significant peaking you can consider it is unstable.
Then add the phase of CL(s): if you see the amplitude decrease while phase increases, it means you have complex poles with positive real part: it means your loop is totally unstable.
Now the question is: what do you mean by "is it stable?"
a 35deg phase margin circuit is stable "mathematically speaking" because it will converge at t=infinity, but will have lots of ringing.
In all cases, the best test to do is to perform a transient simulation with a step stimuli on the input.
English is not my mother tongue, so please excuse my mistakes ^^
