Jul 17th, 2024, 5:22pm
What caused the overshoot? (Read 1075 times)
Mar 08th, 2013, 6:32am
Hi Guys,
I have an analog high pass filter, which has big overshoot. The following is loop gain/phase, step response, and close loop response. I could not figure out the reason of overshoot in the step response from the loop gain/phase and close response. Any comments are appreciated.
Re: What caused the overshoot?
Reply #1 - Mar 8th, 2013, 6:34am
This is the step response with big overshoot.
Reply #2 - Mar 8th, 2013, 6:46am
This is the close loop gain and phase of the output node.
Lex
Eindhoven, Holland
Reply #3 - Mar 8th, 2013, 6:47am
My first guess would be zeros in your transfer function.
raja.cedt
Reply #4 - Mar 8th, 2013, 7:09am
Hello Ywguo,
why it will be surprise to you, if there is no overshoot then you should surprise. High pass filter will contain zeor's at zero frequency. Please provide schematic.
Raj.
RobG
Bozeman, MT
Reply #5 - Mar 9th, 2013, 9:29pm
Look at a simple RC high pass filter and you will see that the step response is a spike just like what you are seeing
threepwood
Reply #6 - Mar 23rd, 2013, 5:26am
Lex wrote on Mar 8th, 2013, 6:47am:
This is the first thing I thought about.
Or it could be charge injections during large-signal stimulation in transient.
Or, if it is a DAC, timing mismatchs between your digits (shifting from 0111 to 1000 for example)
English is not my mother tongue, so please excuse my mistakes ^^
