Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 16
th
, 2024, 5:27am
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› How to plot instantaneous VCO frequency using Cadence Spectre
Previous topic
Next topic
How to plot instantaneous VCO frequency using Cadence Spectre (Read 853 times)
vp1953
Jan 23
rd
, 2013, 6:23pm
I am running a transient simulation (with noise) for a VCO. I want to see what the free running frequency drift of the VCO is. I could take the time interval between zero crossings (or a certain number of zero crossings) and estimate the instantaneous frequency - do this several times and then I can get an idea of the frequency drift of the VCO.
I am wondering if there is automated way to do this - say plot the inverse of the time interval between 10 zero crossings continuously along side the time domain VCO output?
Thank you.
IP Logged
Re: How to plot instantaneous VCO frequency using Cadence Spectre
Reply #1 -
Jan 25
th
, 2013, 4:24am
VP1953,
I think what you want is the calculator function,
freq
, it converts
returns the frequency of the waveform. You can select the level to
use for the zero crossings or it will estimate the level for you.
IP Logged
vp1953
Reply #2 -
Jan 28
th
, 2013, 12:14pm
Hi Sheldon,
Thank you very much. This is exactly what i was looking for.
Best regards..
IP Logged
rf-design
Reiner Franke
Reply #3 -
Feb 21
st
, 2013, 2:40am
If the oscillator frequency is defined by oscillatory energy exchange between an inductor and a capacitor you can use a normalized state-space. The normalized state-space is defined by capacitor voltage and inductor current. You have to normalize so that the oscillatory behaviour gives a circle instead of an ellipse. Than you can extract the angular velocity and get the oscillation frequency in rad/s. Because oscillators also have some nonlinearities there is a ripple in the angular velocity. But you can extract the mean value. This measure is more accurate because finding the zero crossing point by interpolation from some time steps before and after gives additional errors which disturb detailed transient startup or supply impact analysis.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
