Aug 18th, 2024, 3:13am
Design of third-order OTA-C type filter (Read 3348 times)
Jlim
Feb 18th, 2013, 5:32pm
i am going to design third-order OTA-C type filter.i doubt about whether the OTA is same with Gm or not?
Then the picture i attached show the 3rd-order Gm-C filter.Can i know that how the Gm block in CMOS transistor form?
Hope for the help...thanks
buddypoor
Bremen, Germany
Re: Design of third-order OTA-C type filter
Reply #1 - Feb 19th, 2013, 12:05am
Jlim, I am not quite sure what your question really is - however, perhaps it helps that each (ideal) OTA can be considered to be a voltage-controlled current source with a transfer ratio ("gain"), which is described as transconductance gm (in A/V).
Jlim
Reply #2 - Feb 19th, 2013, 12:18am
i dont know how to build "gm" block that show in attachment in CMOS transistor form...Can anyone to help me?
buddypoor
Bremen, Germany
Reply #3 - Feb 19th, 2013, 2:43am
Jlim wrote on Feb 19th, 2013, 12:18am:
What means "build" ? In hardware or as a transistor-based simulation model?
Jlim
Reply #4 - Feb 19th, 2013, 9:00am
thanks to reply...sorry make u confusing...
i want to design Gm as a transistor-based simulation model by using cadence...do u hv any suggestion circuit for me???
