Oct 16th, 2026, 4:08am
QRC's av_extracted view is not showing any metal layers (Read 1095 times)
VINAY RAO
Mar 08th, 2013, 6:27am
Hello all,
             I designed simple inverter using UMC65ll kit and it passed successfully in DRC, LVS, and QRC. But extracted view of this design isn't showing any metal layer instead schematic of transistor is shown (figure attached). I have also ran QRC by setting valid layers (LSW->edit->set valid layers->set all valid) but problem still remains the same. Moreover, I am only using METAL1, DIFFUSION and POLY1 layers. Versions are as follows.
IC 614-06.14-512
Assura 4.1 USR2 with EXT101 &
MMSIM 0720.593
How can I set up this to show layers in av_extracted view?
Vinay Rao.
bernd
Munich/Germany
Re: QRC's av_extracted view is not showing any metal layers
Reply #1 - Mar 12th, 2013, 12:25am
This has been answered here (cross posting)
http://www.cadence.com/Community/forums/p/25556/1321304.aspx#1321304
* bernd
Just another lonesome cad guy
