Jul 16th, 2024, 9:17pm
Sensitivity vs Transmitted power from the transmitter (Read 1087 times)
iVenky
Mar 11th, 2013, 1:58am
Let us assume that I initially had a sensitivity of -90 dBm. Now due to some reason the sensitivity got increased to -84 dBm. This means that we have an increase in sensitivity of 6 db. So 6 db increase in sensitivity indicates how much increase in the transmitter power so that the range is same?
I got the answer as 4 times the initial power but the correct answers seems to be 2 times. Which one is correct?
