kerekuto
Hi PinGuine, thank you for your reply. By strobe component, are you referring to the clock signal (vpulse source)? The other sources I have are only DC sources: VDD, VCM to bias the inputs, and a dc voltage between the inputs to cancel input offset, is this setup correct?
For the PAC analysis, on which source should I apply the PAC magnitude of 1?
Can you give me more details on how to do the integration you mentioned on step 3?
