Nov 10th, 2026, 7:45pm
Comparator ISF using PSS/PAC (Read 11918 times)
kerekuto
Mar 20th, 2013, 4:25pm
Hi, I am trying to simulate the Impulse Sensitivity Function (ISF) of a clocked comparator using SpectreRF as in Kim's paper "Impulse Sensitivity Function Analysis of Periodic Circuits". I’ve already obtained the ISF using the transient-based method, but I would like to compare performance and results. I am not very familiar with PSS or PAC, and all the information I've found in other forums is more geared towards oscillators.
Does anybody know about a good tutorial, or better yet, has anybody tried to reproduce this method?
(Link to the paper: http://www.cecs.uci.edu/~papers/iccad08/PDFs/Papers/05C.2.pdf)
PinGuine
Re: Comparator ISF using PSS/PAC
Reply #1 - Mar 26th, 2013, 12:43pm
Hi
i have simulated ISF using PAC. But special script was needed after simulation to implement approach from paper.
if ISF value at one time point is interested then You can
1. Add strobe component in the testbench. Which will strobe output at interested time.
2.Run PAC.
3. Integrate "sideband 0" from 0hz to Fclock/2. It gives ISF value
kerekuto
Reply #2 - Apr 3rd, 2013, 1:25pm
Hi PinGuine, thank you for your reply. By strobe component, are you referring to the clock signal (vpulse source)? The other sources I have are only DC sources: VDD, VCM to bias the inputs, and a dc voltage between the inputs to cancel input offset, is this setup correct?
For the PAC analysis, on which source should I apply the PAC magnitude of 1?
Can you give me more details on how to do the integration you mentioned on step 3?
880321
Reply #3 - May 7th, 2013, 11:13pm
PinGuine wrote on Mar 26th, 2013, 12:43pm:
Hi
2.Run PAC.
hello,you say spercial script was needed for PAC to get ISF, can you post your script here?
achalk
Mountain View
Reply #4 - Sep 23rd, 2013, 5:08pm
@kerekuto - the slide 20 of the classnotes on dynamic comparators here https://bspace.berkeley.edu/access/content/group/814408c5-19c5-454c-ab95-454a58b... illustrates the idea of strobing the output at fixed time (t_sub_0 in the paper) after the edge of the clock (that sets the frequency to W_sub_c).
and as per my understanding the pac input of magnitude 1 will have to applied at the input of the your clocked comparator.
phlan
Reply #5 - Jun 30th, 2017, 4:54pm
Hi achalk,
the webwite is not available anymore until Jun. 17, 2017. Would you please guide me where can I find the related materials? Appreciate your great helps.
phlan
Reply #6 - Sep 22nd, 2017, 3:00pm
If you have access to the IEEEXplore, you can probably still find the
paper.
Be aware that the measurement is non-trivial even in simulation. There
are simpler methods based on frequency domain simulations.
