Aug 17th, 2024, 10:27pm
comparator bandwidth (Read 4136 times)
lhlbluesky_lhl
Mar 22nd, 2013, 4:43am
in normal case, comparator is used in open-loop, not in closed-loop as feedback-amplifier, so, how to decide the -3db bandwidth of open-loop comparator? is there some formula or guide for the -3db bandwidth calculation of open-loop comparator?
thanks.
wave
Re: comparator bandwidth
Reply #1 - Mar 22nd, 2013, 10:31am
Why not look at Propagation Delay instead?
Reply #2 - Mar 22nd, 2013, 4:39pm
You are trying to determine the BW of a non linear device.
That doesn't really make sense.
BW for a linerar device, yes, but comparators are typically characterized as a function of propagation delay or response time characteristics.
raja.cedt
Reply #3 - Mar 23rd, 2013, 2:28am
in addition to jerry comments, there is lot to estimate for sampler and on the top of that bandwidth doesn't make scene much.
Have a look at this paps
1. Time Resolution of NMOS Sampling Switches Used on Low-Swing Signals
2.Characterizing Sampling Aperture of Clocked Comparators
Have fun,
Raj,
weber8722
Re: comparator bandwidth vs Propagation Delay
Reply #4 - Apr 11th, 2013, 4:56am
best check the delay for different input overdrive, e.g. have one input at 1V and the other with puls from a=0.9V to b=1.05V. Then vary both a and b in a loop. You will see that the delay becomes shorter for large b and large a!!
So there is no single number which describes such highly nonlinear circuit as a comparator.
Also there are different parts in response time: like pure delay (to get out of saturation, then a part for rise or fall time. Smiley Smiley
Bye Stephan
