Aug 17th, 2024, 6:25pm
Cascaded Current mirror low current (Read 4788 times)
neuro11
Apr 03rd, 2013, 1:14am
Hi, this is a differential input Opamp with cascaded current mirror. The mirror circuit looks complex but i know it is supposed to provide a stable output current of 6uA ~7uA. But i am getting very low current in fact nearly zero. Can some one please suggest the reason.....
I have attached the circuit
neuro11
Re: Cascaded Current mirror low current
Reply #1 - Apr 3rd, 2013, 1:15am
and the current output in differential stage
neuro11
Reply #2 - Apr 3rd, 2013, 1:16am
and the current output in  output stage.
raja.cedt
Reply #3 - Apr 3rd, 2013, 1:29am
is P12 gate connection correct????
neuro11
Reply #4 - Apr 3rd, 2013, 1:59am
thanks for looking....
ya the connection is alright. And in the circuit i posted i made a mistake of not connecting the differential inputs base to VDD, but that was not the reason i am not getting the right current.....
Reply #5 - Apr 3rd, 2013, 3:45am
Neuro11,
1) The connection for P12 is incorrect. P12 should be connected to the
    gate of P10. You have connected it to the source of P11, this
    voltage is one threshold voltage less than the gate voltage of
    P10 and is approximately the same as the gate voltage of P9.
2) You should consider using a low dropout mirror, see Johns and
    Martin.
3) Next, why are P6, P11, and N7 in the circuit? What purpose do
   they serve.
4) Why are you using a diode connected transistor to set the bias
    current? If the supply voltage goes up or down the bias current
   will vary significantly. It is worth your time to build a real
   bias current generator.
neuro11
Reply #6 - Apr 3rd, 2013, 6:06am
Thanks a lot for the detail response. I was following a TSMC tutorial and using exactly this current mirror they recieved a stable current.So i tried, for your questions:
1. i exactly thought the same way and rechecked but it seems they were not using p12 for mirroring which is surprising because p12 directly connects to differential pair.
2. thanks for reference i will check
3. i assume they used N7 and p11 to reduce the voltage at which current gets stable. (i am not expert so not sure)
4.ya now i think i should study to make my own. what book you recommend. i want to design a voltage buffer opamp and a differential input opamp. what book you suggest for that.
Reply #7 - Apr 3rd, 2013, 7:15pm
Neuro,
 I think that the NMOS mirrors for the diff pair bias and load were
originally cascoded and N7, P11 biased the cascode.
